I just bought an MS909W and...
Discussion in 'Subwoofers' started by nUMb, Mar 14, 2005.
  1. nUMb
    nUMb
    I just bought an MS909W and am wondering if i can put it in the corner where it is surrounded from three sides. It has approximatly 10 cm in every direction.
    Is that to close to the walls and i shoud consider another position or is it ok to stand that way!
    Any help appreciated!
    Thanks in andvance!
  2. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    should be ok - but why don't you try it..??
  3. nUMb
    nUMb
    heh :) I'm gonna pick it up later today and just wanna have some input from you guys!
    Thanks for the quick reply
    BDW: Do you think 370£ is a good price for a new one??? :devil:
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    By the looks of the going rate it seems to be a bargain.
    But in that sort of territory I'd probably look at the SVS PB10 or that insane but intriguiging Sony 1KW sub (albeit they probably don't look aestetically as pleasing!)
    Good luck with your positional test, at a guess it will sound more powerful located there but it may create a smaller "sweetspot" in the room.
    ...PJ :)
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Cheapest I've seen one is £479
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    £370 is an excellent price for the MS909.
    It will work fine in a corner, maybe not at it's best but if you can only put it in one place then that's where it has to go! :)
  7. nUMb
    nUMb
    Thanks for your quick reply! Will post my observations here once i do the full test :devil:
