I have upto £1500 which 37" plasma would be best?
Discussion in 'Plasma TVs Forum' started by superduper, Jul 16, 2005.
  1. superduper
    superduper
    Hi I have upto £1500 to spend on a plasma I want a 37" any idea's which would be the best in this price range?
    I have been looking at the Sony KE-P37M1 what do you think?
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    The Panasonic PA50 is available delivered with either wall bracket or pedastal stand for £1250.
    http://www.digital-point.co.uk/model.php?ID=2021&source=kelkoo
    I think that is an awesome 37" set.
    Or you can get the HD-Ready TH37PV500WAL from them for £1700 and something, not sure how this compares with other prices?
    Have Sony got decent plasmas now? From reading the specs of that set it doesn't accept any of the Hi-Def formats at all, only progressive scan, so it will be out of date in 6 months time.
