I have two SkyDigital boxes...
Discussion in 'Sky Digital TV Forum' started by mmm, Dec 10, 2002.
  1. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    I have SkyDigital currently installed. When I moved from my old house, I also took the box (not the dish).
    Would it be possible to have just a card that can allow me to view the freeview channels and the spare box ? and have the satelite signal split between the two ?
    regards
    m
  2. Azrikam
    Azrikam
    AFAIK, you can do this as long as you have a dual (or quad) LNB on your Sky dish. Each box needs a separate feed to the dish, and it's not sufficient to split the cable after the fact.
    As for the card, you can get a free-to-air card from the BBC that will work with the box to give you all the free to air channels, provided you have the right connection to the dish.
