I have the AE 100 What else do I need?
Discussion in 'Projectors, Screens & Video Processors' started by martinnaylor10, Jul 9, 2002.
  1. martinnaylor10
    martinnaylor10
    I now have my panny AE 100 pj,together with a prog scan dvd player and a home made screen,at the moment the player is hooked up via a component cable,can I get a better picture by somehow connecting the player to the vga input on the pj?
    If so what cable do I need and where do I get one from.Also what if anything else could make it better (apart from a proper screen)?
    Any help will be appreciated.
    Martin
  2. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    You can get a keydigital transcoder from the states, this will convert the componant input into a vga output to connect to the AE100, its about £300 :eek: and you would probably not get 576p for progressive pal on the AE100 with this transcoder. Do a search here for keydigital if you need to go into it a bit more.
    If you want to improve over the progressive dvd player you would probably be best going the HTPC route.
