I have problem in Denon 1908
Discussion in 'AV Receivers & Amplifiers' started by jvbint, Jun 16, 2009.
Tags:
  1. jvbint
    jvbint
    Mar 12, 2009
    9
    i have denon 1908 av reciever. Most of time i use this with generator because of power problem. I have been facing a problem that whenever i connect my pioneer dvd with amp thru hdmi and amp to lcd again hdmi, it sounds some sparking noise from speaker, like some electric spark or something and later amp come to safe mode. But when i attach dvd direct to tv with hdmi and coaxil to amp, it works properly. I have informed denon people also but they are also confused about this. They say that it may because of generator power supply. If it is that then why it work well with coaxial.
    Any body can help me in this ?
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    You must use power conditioning with a generator. They are at best for emergency use only and if you want to protect your gear you should use a conditioner.
  3. jvbint
    jvbint
    Mar 12, 2009
    9
    Thanks for this. I will install a power conditioner then check.
