i have downloaded something and it needs xvid
kopchoir
as title i have downloaded something that needs xvid i have downloaded xvid i think but it still doesnt work anyone help
t1m103
kopchoir
its all this codec rubbish im not clued up on i understand the principles of the codecs kind of thing i.e you need teh relevant code to play it but still lost im now trying mr incredibles link
t1m103
whats the file your trying to play?
Razor
D
Deleted member 39241
Stay away from codec packs in my opinion, try and keep your PC as free from un-needed stuff as possible. Divx codec will also playback xvid files, but I recommend this decoder:
Xvid Codec
More information at www.xvid.org. Once installed you should be able to play the file back in Windows Media Player, or any other player on your system.
GETanner
Another vote for VLC as a good player. It does not require codecs to be install to play xvid files, thus making it nice and neat.
I assume you're using Windows Media Player to try and view the file. Even with the correct codec installed, it can be a hassle to get it to work.
The codec for xvid can be obtained here http://www.free-codecs.com/download/Koepi_XviD.htm though I would strongly suggest you get VLC and use that instead.
WMP does like to hijack file-type settings and even with VLC installed, you may have to right-click the file and select "open-with" and then choosing VLC from the available list rather than double-clicking the file.
G
kopchoir
have just deleted the file and will try and download again in a different format thanks for all the help
mods close
sore napper
If your DVD Player can play Divx there's a good chance that it will play xvid and avi files.
If it does play these, burn the file as a data disc and play in the dvd player.
