I have blown these speakers up
Discussion in 'Home Cinema Speakers' started by 50/50, Apr 8, 2003.
  1. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    My mate lent me his Whalfedale Valdus 300's for a party I had on the weekend.. It had been running of a Nad C370(bridged) and a nad mono block that was the same power as the amp. The amps were also his. I believe thay had about 300w per channel.
    The speakers were rated at 120w. But He assured me that he had been running them to the full extent of the amps without any problems.
    The night was going fine and the sound was great, until **BANG**. the left speaker cone 'exploded'..
    The cone is still on the frame, but it plays sound with distortion at low volumes.
    The right speaker is fine.
    Is it fix-able ?
    My mate wasnt at the party.. so he doesnt know yet
    :rolleyes:
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Oh dear!! Spoilt the party too, I bet. :( Contact Wharfedale and ask them if they do a replacement cone. Should be cheap too. If you replace one cone only, the speakers may sound a little diff. until the new one is run-in too.:rotfl: You'll probably have to own up to the problem anyway, your mate will surely understand;)
  3. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    I delt with warfedale once when a driver cone started to play up. They asked me to remove the drive unit and sent it to them for matching. I recived a replacement within a week. The engineer called to find out if i wanted help fitting the new unit. Excellent sevice and very reasonable on price too. Give em a ring I found them very helpful.
    When is your mate expecting it back?:zonked:
  4. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Jeez, a bridged c370 has a dynamic output of about 400W. :eek:
    I would try contacting Wharfedale as has been suggested. Double check that right cone as well - might be fubar.
    MuFu.
  5. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    I rang Wharfedale, and they said they would send me out a driver, and It would be with me, within 2 weeks...
    I havent told my mate yet.. I dont think I will...
    :smoke:
  6. mjn
    mjn
    May 24, 2001
    22,258
    Herts, England
    +10,107
    i'm trying hard not to laugh........ :)
  7. Sunday Ironfoot
    Sunday Ironfoot
    Just how are you going to tell your mate that he won't get his speakers back for two weeks :D
