Question I have a problem with my Panasonic Viera
Discussion in 'Panasonic TVs Forum' started by Sundown444, Jul 21, 2018.
  1. Sundown444
    Sundown444
    Jul 21, 2018
    4
    Utah
    On the Panasonic Viera TV I am using, I am having an issue. The screen changes (partly sometimes) between what is playing on TV and a picture that says TV One. I need to know how to get rid of it. What should I do?
  2. Retro Hedgehog
    Retro Hedgehog
    Aug 5, 2018
    12
    England
    +9
    It sounds like the TV is switching from TV to another input source. All I can advise is to check what connections you have to your TV and see if any of these are signalling to the TVs auto input detector. For example, on many TVs if you turn on your bluray player or games console the TV will recognise that this device has turned on and change the input source from TV aerial to the HDMI connection (so it will show the bluray/consoles output).
    You might be able to work out what is causing it by removing all HDMI connections and checking that this problem goes away. Then gradually plug each one back in over several TV viewings to find out if it is one piece of connected equipment.
    You might also be able to turn off HDMI / input auto detect in your TV settings.
