I have a problem, can anyone help ?
Discussion in 'Headphones, Earphones & Portable Music' started by Rabbitslim, Sep 5, 2004.
  1. Rabbitslim
    Rabbitslim
    Hi everyone.
    I have recently purchased a Panasonic pwd6 (a great bit of kit by the way) but it doesn’t have any speakers or a headphone socket (this is not out of ignorance I did know before I bought it).
    I have an amp so I can enjoy a truly cinema like effect at home, but hears where my problem comes in. at night not every one likes to have a cinema in there front room, especially when they are trying to sleep.
    So I need a pair of headphones, but as I have said there is no socket on the plasma so I need to somehow connect them straight to my dvd player.
    So this is my question, is there such a thing as phono headphones or is there some kind of adaptor I can buy.
    All help would be much appreciated, as I’m starting to get very evil looks at breakfast.
    Thanks Lee.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Can you not connect them to your amp?
  3. Rabbitslim
    Rabbitslim
    thanks david.
    but no my amp dose not have a headphone socket, or any outputs for that matter. just the ones going to the speakers.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK if amp has a TAPE loop not used, ie a line level output, then get a head phone amp takes stereo analog input and give you volume control then a decent set of headphones and away you go!
  5. Rabbitslim
    Rabbitslim
  6. Rabbitslim
    Rabbitslim
    also if i used the above options would i be able to control the vol.
    if not is there somthing i could get to do that as well.
  7. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    That lead in the link you posted with the two phono to female jack plug looks like it will work . I am pretty sure you can by headphones with volume controll built in. My dad used to have a pair of philips ones. I will do some hunting about and see what I can find :)
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Right . go to google. Search the uk only for , headphones with volume controll. should give you some options. Tried to post a link but could not get it to work :)
  9. Rabbitslim
    Rabbitslim
    Cheers david.
    i thought that it would work. ill have a look round for some headphones now.
  10. bobbypunk
    bobbypunk
    sennheiser hd62tv about £40 individual left and right volume control!
  11. Rabbitslim
    Rabbitslim
    Thanks bobby, i'll check those out.
    dose anyone els have any suggestions on what headphones i should get?
    they need to have an in-line volume control.
    Thanks Lee.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Pre amp and some decent Cans...... only way to go....
