I have a pdw6 problem!
Discussion in 'Plasma TVs' started by Macleanrd, Dec 17, 2004.
  1. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    It would be much appreciated if anyone can answer a problem for me.
    I have just set up my new pany pw6 and its amazing.......but
    When i play a dvd through my pany home cinama system the picture and 5.1 surround is great but when i switch to tv i get great 5.1 surround but no picture.
    I am connected as follows
    I have skyplus which is connected to the plasma's vga socket by scart from my skyplus
    My surround dvd system is connected by scart that connects to the second scart socket on the skyplus
    I loose the picture when i go from dvd to tv
    I have found that if i pull the scart lead a out a little from the scart connection the picture comes on for tv but i only have the centre speaker and left front , if i push it in i loose picture but gain correct sound, too far out and i loose both.
    please help as im pulling my hair out and i aint got much to start with
  2. absthechatter
    absthechatter
    Nov 27, 2004
    159
    Have you tried swapping the scart cables around? You know the DVD one is working so give that a try, even if it isn't that you can rule it out.
    Abs
  3. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    i have tried various scart cables but it always happens so its not a broken cable
    Im conected my home thearte dvd scart via the vcr scart connection on sky plus, the other sky plus scart connection is converted to go into the vga on plasma, still no picture when sky is on but i have sound, dvd is ok......buy the way i have no terminals installed.....could not afford the lol
  4. jont
    jont
    Apr 8, 2002
    3,939
    near Aylesbury
    +416
    Have you ever had a sky+ tv picture without the panny connected ?
    Are you just pressing the 'tv' button on the sky handset to switch ? AFAIK that only works with an rf arial feed int the sky+ box and bypasses the sat feeds ... no arial feed no picture ?
    Jon
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    you have not set your sky+ to output RGB
    go into the setup menu and select the output as RGB
    DO NOT press the "TV" button on the sky remote, it turns RGB off
    PRESS the "sky" button on your sky remote, it turns RGB on
  6. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    I have rgb on.
    I have found that to get sky with picture and sound i have to pull out scart from home cinama and plug in a scart lead, the other end of this goes into the sky box to the audio left and right inputs, this is ok but if i want to watch a dvd i have to pull out scart on home cinama and connect the other end to the vcr scart on sky which is frustrating
    help
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    use a JS MSC so they can both connect to the RGB>VGA box at same time.....
  8. jont
    jont
    Apr 8, 2002
    3,939
    near Aylesbury
    +416
    OK ... have you got a fully wired scart lead ? or is it just a 'one-way' one ?
    I assume you are switching off the home cinema box when you want to watch sky ... if the home cinema box is 'on' it will take priority on the video pass through on the sky+ box ... you'll to press the 'sky' button to get it to switch to the sky as the main source and ignore anything on pass-through ...
    Jon
  9. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Tried all that Jon...still no good.....have now resigned myself to just unplugging the scart from home cinima and sky vcr and then connecting a scart to home cinima and the other end ( which is 3 imputs l r and video) to just the l and r inputs on sky, once ive done this i have pic and sound, its a pain but i cannot afford a scart terminal board( all ive got is the vga that came with plasma.
    Many thanks to those that have tried to help
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
  11. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    I have no js convertor.........I am currently using a scart one end and vga the other end lead.....surly i only now require a msc
    Help im so confused
    ps
    at the end of the day i want sound and picture when i play dvds and when i watch sky........the amp is part of the dvd(home cinama)5.1) so when im watching sky i have sound via the home cinama(built into dvd player)
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    sorry the JS box is a more accomplished converter that a sync extractor cable like yours... so all you would need is an MSC and get them plugged in the right way round..... FV into priority input
  13. harry mungus
    harry mungus
    I have a similar system in which my screen is connected to my dvd player directly by component video cables and my sky box is connected to the VGA input on my screen and scart at the box. My sky box has a set of audio leads which connect between that and the dvd player. When I watch a DVD I change the input on my Panisonic screen to COMPONENT and when I am watching SKY I switch the input to PC.
    Hope this helps.
  14. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Thanks, as my dvd hasnt got component what terminal board do i need , my dvd has scart so what cable will i need.........i can connect sky and dvd with audio cables .
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    IF DVD will ouput RGB (most will you can connect it to the VGA input of plasma) I reconmend the JS RGB>VGA converter and MSC (master scart controlller)
  16. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    How much will that cost, as i got my pw6, scart to vga lead, and wall bracket for £1566 inc vat, and dont want the cost to spiral lol and get in trouble with the wife.
  17. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Still waiting for reply to above post.........can anyone help?
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    js box rgb>vga is £150 and a component board BNC is £80 ish (depends where you bought the screen from)
