I have 3910 with denon link 3rd
Discussion in 'Blu-ray & DVD Players & Recorders' started by rszee, Jul 2, 2005.
  1. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    I have a 3910 with denon link 3rd BUT its not showing on the set up menu
    The firmware is 6609-B which I believe is the latest firmware
    I had it multi regioned
    Does anyone have any ideas why its not showing in the set up menu when the info leaflet from Denon said it should be.
  2. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    Sorry to suggest the bloody obvious - but are you trying to do this with a disc in the machine? You can't switch on Denon link if you have a disc in the tray.
  3. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    I have found out why, This is because there is only R2 firmware that has Denon Link 3rd. Mine is MR and there isn't firmware yet that has MR+DL3rd
    I will have to wait for an update from Denon.
  4. David Allum
    David Allum
    Jul 27, 2002
    3
    Earth That Was
    +6
  5. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    I have now got R2 DL3rd (got 3 cds sent from Denon)
    I am debating wether or not to use the MR firmware hosted in the forums or wait for 7oaks to obtain it and let them do it(they said they would do it free)
    emmmmmmmmmmmmmmmm
  6. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    MR installed from dealer
    sorted
  7. 12 promises
    12 promises
    Aug 18, 2004
    1,549
    2
    dunfermline
    +116
    how did you get the discs?
  8. rszee
    rszee
    May 7, 2005
    194
    Kent
    +42
    I emailed denon and asked if they would send me the DL3 firmare update (R2 only)
    Or you can try your dealer if it is convenient for you.
    Make sure you read the instructions you get with the update coz you can crash the player and that means that I.C 104 (I think) would need replacing.
