i got the 52 element AERIAL from argos
Discussion in 'Satellite TV, Sky TV & FreeSat' started by chilpillphil, Jan 3, 2004.
  1. chilpillphil
    chilpillphil
    it doesnt pick up signal
    sn34bd is my post code
    on my bungalow will i make any difference if i position outside
    does it matter if its on the chimmney
    im quite experience but never been the roof is it safe
    please help
    the aerial man wanted upto £200 :(
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Not really sure what you're asking here....if you're saying that that the aerial is currently indoors,then it's no surprise that you aren't getting much of a signal.
    Ideally the aerial should be mounted as high as possible(thus chimney mounting is usually chosen)and it will need to be positioned to receive the signal from the nearest/strongest transmitter available to you.
    If you haven't had experience of fitting external aerials,it's a job best left to an experienced fitter,although you should be able to get a cheaper quote by phoning around a bit.
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,120
    48
    republic of ireland now
    +56
    chilphil, check out the bbc site for digital and see what they suggest for your area, should tell how strong a signal u can expect. follow links for DIGITAL
    gb--
  4. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    That model won't work if you live at number 6 :eek: ;)
  5. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    £200 is extemly high just to fit an ariel. We got one put up last July , 5 stories up and a flat roof as well , for £60 from a local guy.
    Shop around , you will get it cheaper and it is best to get someone experience to do it for you.
    General Panic
