I give up! Setting the 2805...
Discussion in 'AV Receivers & Amplifiers' started by swarrans, Nov 2, 2004.
  1. swarrans
    swarrans
    Dec 21, 2001
    404
    16
    Kent, UK
    I know this is going to make me the dimmest person on these forums, but I simply can't understand how to make the Denon 2805 "automatic" set up work! I (think) I've followed the manual, but when I plug the microphone in and then press the button to (I thought) make the system cycle through the speakers by playing white noise through each one in turn, nothing happens!
    Any ideas what I've done wrong?....
    I had a previous problem when I didn't get any sound at all which was "cured" by pressing the button to turn the speakers on, so this will give you a clue on my state of mental challenge!
    Simon
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,240
    48
    London
    +95
    May be an obvious thing but - when you are going to the auto setup option I assume that you are clicking left on the remote rather than the select/ok button? Sorry if this is insulting but it is what flumuxed me when I first attempted to set the thing up.
  3. swarrans
    swarrans
    Dec 21, 2001
    404
    16
    Kent, UK
    You were spot on Astaroth - thanks!
    It seems so counter-intuitive to me to use the left cursor button for that function when the select button is used for every other operation, I'm not surprised "we" missed it! Looking back at the manual I can now see it tells you to do this, but I find I can only understand what the manual says after I understand the logic (if that makes sense!).
    My remore control seems to be very hit and miss (even when I press the correct button!) - sometimes it seems to send the command and sometimes not.
    Anyway, happy now - thanks
    Simon
