I don't want to get all 'MTV Cribs' on you guys...
Discussion in 'Plasma TVs Forum' started by Hicksy, Aug 18, 2004.
  1. Hicksy
    Hicksy
    ...but seeing as a lot of time is spent in the bathroom, has anybody rigged up a small LCD in there? (obviously not forgetting that water and electrics don't mix!!!). Beats reading FHM!
    THought I'd ask!!
    Hicksy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    We can supply you with a unit specifically designed for that purpose mate an Aquavision Bathroom LCD, Waterproof and with a Floating remote! ;) now that is a funky/Fancy bit of kit!!!
  3. Hicksy
    Hicksy
    ..and the price?? (wait for it!!) :laugh:
    is it on the web?
  4. wb1
    wb1
    Sep 5, 2003
    1,673
    38
    London
    +21
    Yep I've used neovo monitors in stud walls with a glass front and an aluminium frame cut so you only see the "screen" not the monitor bezel.
    The neovo monitors have their s-video input hooked up to a sky box and I've used Xantech ir-repeaters to get the remote signal to the sky box in a cupboard in the bedroom. Oh and a seperate amp to drive the ceiling speakers.
    I should do some photos and a rough guide to how I did it if only I could find the time!...
    Let me know if you have q's...
  5. Hicksy
    Hicksy
    [email protected]@dy hell mate, thats doing it!
    Any way of doing it at a relatively low cost? Any websites?
    thanks
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    need heated glass really otherwise it steams up.....
    http://www.boundarybathrooms.co.uk/aquavision-bathroom-televisions.html
    some ok pics lifted from brochures etc.
    Aquavision are the nuts, or tilevision are a cheaper option.
    http://www.porta.co.uk/main.html
    DIY option is possible but adding heated glass makes it almost as much as a proper unit.
    Another option away from wet area's is this: http://www.aviproducts.com/fliptv.html
    Phillips have developed an LCD panel that you can stick to any peice of glass,
  7. wb1
    wb1
    Sep 5, 2003
    1,673
    38
    London
    +21
    Mine may not have heated glass but they do the biz at less than a quarter of the price of the aquavision, tilevision etc.
    Maybe I should sell them... :D
  8. wb1
    wb1
    Sep 5, 2003
    1,673
    38
    London
    +21
    Oh - forgot to mention we did put an anti mist treatment on the glass - same stuff you use for glasses, helmet visors etc and it works a treat... ;-)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    CI installers have been doing it for years mate, a fair few B&O sets have been built into the end of Baths etc.
    Best one i have seen is a 42" plasma built into a cabinet in a guys garden for use while he is in his hot tub. Nice thing with Aquavision etc is they can be built into shower cubicles etc quickly and relatively easily.
  10. RustyH
    RustyH
    Im just about hook up a 15" job in front of my whirlpool, its it also connected to a networked computer in the loft and fully controls My HTPC with music, vidoes, etc.
    Can I get a floating remote that is compatible for my screen
  11. RustyH
    RustyH
    By the way, im after a glass/aluminium or stainless steel panel for over the top of it, can any of you guys help me out there????
  12. Rollin
    Rollin
    Go here... http://www.schaeffer-apparatebau.de/English/FPD_index.htm
    You can design a frame using the software. It tells you how much it will cost. Enter your card details and they cut the frame to your spec and post it to you from Germany.
    I did it for a frame for a 15" screen and it's perfect.
