I don't like wooden box speakers with black fronts.. any other options?
Discussion in 'Home Cinema Speakers' started by Scoobiesnacks, Oct 30, 2005.
  1. Scoobiesnacks
    Scoobiesnacks
    Jan 1, 2004
    565
    Manchester
    +19
    I'm not a speakers expert and would like some advice please on non traditional options for speakers.
    Basically I don't like rectangular wooden box speakers with black fronts, are there any other options that are more stylish?
    Sony used to have some nice rounded shaped speakers but I'm not sure they do them anymore.
    They are to go with one of these..
    http://www.johnlewis.com/Audio+and+TV/DAB+Digital+Radios/+By+Brand+/Onkyo/230202570/Product.aspx
    Recommendations welcome!
  2. conkerman
    conkerman
    Feb 21, 2005
    494
    28
    +39
    Check out the blueroom minipods. They sound like just what you are looking for!!
    Still one of the most distinctive speakers about, they were developed by B&W IIRC.
    Bit expensive though, you would probably be best served buying a seperates syste.
  3. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,816
    41
    Kent
    +18
    Not cheap, but how about...
    Anthony Gallo
    od Celestions have some nice speakers. AV501s or AVS302
    There's plenty with style,
    Mark.
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,224
    83
    Over the Hill & Far Away
    +142
    B&w and Tannoy do funky sat sub systems.. again not cheap...but very nice..
    Or Mission's M-Cubes..
  5. Beobloke
    Beobloke
    Aug 10, 2004
    1,315
    Out in the Sticks!
    +67
  6. Falp
    Falp
    Apr 23, 2004
    1,677
    48
    Lisbon
    KEF 2005 Eggs...
    Canton...
    Acoustic-Reality...
    B&W XT...
    Audica...
    Just a few...
  7. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    If you go the DIY route the options are huge or how about some electrostatics
  8. jessmith
    jessmith
    Mar 9, 2005
    141
    19
    mission cubes are another option, or there are a lot of in wall speakers by the likes of KEF. If you have a lot of £ to spare Martin Logan, Wilson or Magnepan have non boxy options.
  9. Scoobiesnacks
    Scoobiesnacks
    Jan 1, 2004
    565
    Manchester
    +19
    thanks for the replies so far
    I've realised I should have given an idea of price and size in my original post.
    Price wise - I'm looking for something in the £250 region, max. Any cheaper great.
    Size wise - a bit smaller than a traditional 2 box set. Nothing on stands, these will be on a wooden shelf.
    I've not investigated all the above options yet but one of the above replies led me to the B&W m-1 which is the sort of look and size I am after. No idea if they are any good though or how much they cost or if they are suitable for music as they come in a home cinema system
    http://www.bwspeakers.com/index.cfm/fuseaction/products.ranges/Label/Range Mini Theatre
  10. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
  11. NMyTree
    NMyTree
    Depending on your budget, Wharfedale has a few options you may want to audition.
    The Opus being the most expensive and highest quality range, followed by the Evolution series and then the Diamond 9.
    All three have speakers with curved side panels..... or as Wharfedale calls it....."curvaceous".
    The Opus series:
    http://www.wharfedale.co.uk/range.php?range_id=1
    The Evolution series:
    http://www.wharfedale.co.uk/range.php?range_id=2
    The Diamond 9 series:
    http://www.wharfedale.co.uk/range.php?range_id=3
  12. conkerman
    conkerman
    Feb 21, 2005
    494
    28
    +39
    Just reading through, and a lot of the options listed will require a sub. I have the B&W M-1's and would not use them without a sub.
    Check out the minipods, you should be able to get an ex demo pair within your budget.
    Wharfedale evo 10 are a cracking pair of speakers.
    Have fun, there's loads out there!
