I don't believe them!
Discussion in 'LCD & LED LCD TVs Forum' started by Madkitty, Jul 21, 2005.
Tags:
  1. Madkitty
    Madkitty
    Jul 21, 2005
    382
    Ok so I bought a new pwetty 17" LCD from Argos for the bedroom - its currently connected to the downstairs Sky+ box and the picture is terrible :mad: It Cant be anything to do with the connection as my previous TV was fine - spoken to tech support and they say you won't get a perfect picture from an LCD on a cable extension. I know I don't know much technically but this seems crazy...are they right?
  2. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    what do you mean by a cable extension...are you using a magic eye?
  3. Madkitty
    Madkitty
    Jul 21, 2005
    382
    told you not very technical :rotfl: coax cable from the box downstairs to tv upstairs and then yes the magic eye
  4. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    get a freeview box for the bedroom.
  5. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    mmmmmm, im worried now because im about to but the samsung 26 and plan to use it exactly the same way...will give samsung a call
  6. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Yup, all the LCD TVs I've tried give nasty results from the RF input. Probably something to do with noise present on this connection type that the TV then has to filter. Agree with akki, get a second decoder or a new Freeview one.
  7. Madkitty
    Madkitty
    Jul 21, 2005
    382
    then I cant watch things on the sky planner :eek:
  8. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    anyone else aware of this problem...probably not worth spending £600 on a new LCD
  9. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    If you feed a quality connection to the TV, it will look great. Run a Coax the length of your house and its going to look like a turd!
    You could always wall mount your CRT. That will look ace. :rotfl:
  10. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    RF feed looks good on our Samsung 15" LCD.
    I have an aerial amplifier about a foot down from the actual aerial so that may have helped.
  11. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I run a RF feed through a Pace twin and a few other things then via a distribution amplifier to a 17" Sony LCD and 2 other CRT's. There is a little snow on the LCD but is so fine it may even be dither. Otherwise, the picture is very watchable and unless you looked close you would not see the snow.
    Maybe a distribution amplifier is the way to go for a second system - our one provides magic eye support for the Pace box so would probably be compatible with the magic eye for Sky boxes.
    -Ian
  12. Cyclone
    Cyclone
    May 23, 2005
    404
    28
    +44
    The RF connection from my SKY box (downstairs) to my Acer 26" (Bedroom) looked quite bad, I now get a 'much' better picture using the AEI digisender (from Argos). The picture quality is about the same as a direct composite cable.
