I do want to see DVD when driving...
Discussion in 'Portable Disc & Media Players & Recorders' started by Brendy300, May 14, 2005.
  1. Brendy300
    Brendy300
    deleted
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +667
    I don't suppose you are in the States are you?
    I know certain states are now banning navigation systems that use a screen.
    I can't help you on the Pioneer system because I can't find anything about it on the net, are you sure that is the correct model number?
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    I hope that doesn't get taken up here. I'd be (literally) lost without TomTom. I'm sure it makes me a safer driver as well as I no longer have last minute lane changes :) A quick glance at the screen is 100 times more effective than listening to the instructions.
  4. Brendy300
    Brendy300
    We figured it out a day later! You need a switch to bypass it. Thanks for the replies!
