I cant go online
Discussion in 'General Video Gaming Chat' started by blocked, Dec 2, 2004.
  1. blocked
    blocked
    hello everbody can you help me in this problem please ?
    i bought a X Box and starter kit but when i enter X box live there is a message come say that i have to update when i clicked ok its take sevral mins then told me its cant update because a technecal problems try again later can you tell me what i have to do plz
  2. blocked
    blocked
    4 views but no one told me the solve :(
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Doesn't it give you the option to check the network connection out when this happens ? Normally it will let you do this and give you a more detailed explanation of what went wrong.
    You might get more help if you specify exactly what you've got, is your XBox modified ? How are you connecting to broadband ICS ? router ? direct connection. If all else fails phone Microsoft, that's what you pay all that money for.
  4. Azrikam
    Azrikam
    I had the same error messages when I was setting up Live. Check that your router is compatible with Live. With me (US Robotics Modem/Router), I upgraded the firmware on the router and it fixed the problem right away.
  5. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    Are you using a Wireless setup ? This is a common problem with wireless connections and live. Otherwise as the previous poster said try connecting your xbox directly to the net instead of through your router.
    This is what I did when I had this problem a while back.
    Also have you tried contacting Xbox live support, if you have a straight forward setup they can normally help you get it working.
  6. blocked
    blocked
    i have a router but i dont know if its work with x box or not its called CHRONES.. how i can report my router ?? could you explain more for me plz
  7. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    Have you tried ringing Live Technical support ?
  8. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    0800 587 1102, since I just phoned them for some other reason.
  9. blocked
    blocked
    thanx guys for helping me
