I can't find the right DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by fugitive, Mar 24, 2006.
  1. fugitive
    fugitive
    Feb 23, 2005
    41
    I want a DVD player which has the following
    DTS
    Progressive scan
    DivX
    Multi-region
    Optical audio out
    I don't want to spend much as I will upgrade to HD/blu-ray soon.
    I've looked at the Pioneer DV-380 but it doesn't have optical out.
    I've looked at the DV-585 which is more than I wanted to spend but seems to have issues with making it multi-region.
    I've looked at a Phillips one which has PRog scan and Divx but no DTS :confused:
    I've got the Toshiba 52" DLP and need optical out to connect it to my sony DAVS 800.
    What else can I consider ?
    thanks in anticipation.
  2. jackal
    jackal
    Take a look at Kiss
  3. DrPepper
    DrPepper
    Oct 2, 2001
    3,424
    Barking Essex
    +282
    If the Phillips does Optical audio are you not gone get DTS from AV amp?
    What AV amp do you have?
  4. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Many Panasonics do all of that except Divx
  5. fugitive
    fugitive
    Feb 23, 2005
    41
    I use the Sony Davs 800 as my DVD/AV amp.
    I'll need to check back and see if the Phillips has optical audio out (i don't think it did)
  6. fugitive
    fugitive
    Feb 23, 2005
    41
    DivX is a must.
    Is there not problems making Pans multi-region - I thought they had to be hardware fixes ?
  7. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    If it has an optical out it will do DTS. I have the Philips DVP5900 which doesn't say DTS in the specs but it does do it through it's digital audio out; unfortunately for you this model only has coaxial out, not optical.
    I believe the Samsung HD850 and HD950 meet all of these requirements.
  8. lar77
    lar77
    Dec 7, 2005
    367
    +15
    The philips 5100 does all if it (but not 100% sure about the optical out but def have digital coxal out). Multiregion is a remote hack. I got one for the divx playback and can't complain.
  9. fugitive
    fugitive
    Feb 23, 2005
    41
    I will do. What do you reckon - A DP-470 ?
  10. lar77
    lar77
    Dec 7, 2005
    367
    +15
    The DP 600 should be out soon ..... fingers crossed
  11. Dunwa
    Dunwa
    Oct 13, 2004
    1,185
    63
    Sydney
    +129
    I have the Philips DVP5900 and I can confirm it doesn't have optical out ... but I bought a Coax to optical convertor for £15 at Maplin and problem solved
  12. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    no problems with making it multi-region afaik, can be had for under £100 with multi-region enabled :thumbsup:
    CLICK HERE
  13. fugitive
    fugitive
    Feb 23, 2005
    41
    Rhino you are a hero - this looks like the one for me and for less than £100 - nice one :clap: :thumbsup:
  14. fugitive
    fugitive
    Feb 23, 2005
    41
    Just a quick update incase anyone is in the same boat.
    I got the DV-585 from the link above and am absolutely delighted with it.
    I link it to my DAVS with an optical audio cable and connect it to my Toshiba 52 by component video cables.
    The result is stunning. I watched all the LOTR dvds at the weekend and the picture was breathtaking.
    Thanks to all those who answered, I can highly recommend this player.
