I cant find the cable i need
Discussion in 'Cables & Switches' started by davyb, Jan 18, 2004.
  1. davyb
    davyb
    Hi guys. I have just bought a sanyo z2 and am trying to hook it up to a marantz dvd 4100 and a skyplus box. I used s-video to hook up the pj and the skyplus, but i only have scart on my dvd. Rather than replace the dvd player, i would like to get a scart cable 10m long to rgb, or component video as it is known. Is there such a thing? And if so where can i buy it without breaking the bank. I dont really want to replace the dvd player. What are my options?
    Davyb.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    S-video cable from DVD? or an RGB>YUV converter
  3. JRHAY72
    JRHAY72
    Keene Electronics do a 10m Scart to RGsB (Component) cable for £50.
    Product code SBB75.
    They also do a cheaper Vivanco branded version for £30 (code KLD162).
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Not sure if Z2 will take RGsB via its component input. BEst check the manual.
  5. davyb
    davyb
    Thanks for your help guys. Can someone tell me what RGsB is? what is the difference between that and rgb? The cables from Keene are just what I am looking for if i can figure out if RGsB can be used on the Z2?
  6. davyb
    davyb
    Horny, what is a yuv converter?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    RGsB is ~RGB with sync on green RGB proper is RGBHV H=horizontal sync, V=Vertical Sync RGsB Is RGB with sync combined on green a Scart use composite video pin for sync signals IIRC.
    An RGB>YUV converter is an active component that actaually converts from one signal type to the other.
    See HERE:http://www.js-technology.com/rgb-yuv/index.htm
  8. davyb
    davyb
    Thanks Horny. So ddoes anyone know if RGsB can be used with the Z2?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Sugest you try in LCD PJ forum mate post the keene link and ask if this will work.
