I can't find any reviews for the SC-HT37R
Discussion in 'Home Cinema Buying & Building' started by xaser1066, Sep 8, 2004.
  1. xaser1066
    xaser1066
    Hi :hiya: , the panny SC-HT37R looks like just the ticket for me and at £772 seems very good value for the money, but does anybody know if it is any good? I was hoping to buy this and the new PT-AE700 projector (if I can wait that long) to create the perfect home cinema :D (well on my budget anyway). What do you think? :smashin:
  2. bobbypunk
    bobbypunk
    It is a DMRE85EBS and a SCHT07
    if that helps
    The DMRE85EBS is very well and widely reviewed and the SCHT07 is alright but not much better than an equivelant priced AV system. I would reccomend the Dmre85 and seperate amp and speakers.
  3. xaser1066
    xaser1066
    Thanks for the help
