I can play it OK on PC, but not on my DVD player!!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Eee-Tee, Jun 2, 2003.
  1. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    I've sucessfully captured, edited and burnt a 61 min DVD w/ the lot- transitions, 2x menus, soundtrack ect.
    BUT, when i try to play it on my stand alone DVD player, the first 16, out of 26 chapters play fine, but the ones after that dont- when i try to play these, there's no sound, and scenes are missed out- its kina semi-frozen.
    I assumed something had cocked up during the burning process, but when i play it on my pc, with either Cyberlink power DVD or windows media, it plays faultlessly
    Any ideas pls?
    :confused:
  2. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    What brand of DVDR did you use? They can be very picky with DVD players but usually always play fine on your PC. It's probably that.
  3. David
    David
    Nov 26, 2002
    221
    16
    London
    Are you sure your set-top player will play DVDRs?
