I can hear my mouse?
Discussion in 'Computer Peripherals & Consumables' started by alancolledge, Jun 19, 2004.
  1. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    And other noises in the background on my computer. :confused:
    It is 3 months old, 3gHz and I have noticed a progressive up in volume of this lately.
    I have just done a search and I couldn't find any similar problems.
    Is there a simple desktop solution for this or do I need to take the computer apart?
    I don't know the motherboard to hand and I have a tv capture card which 'leeks' sound from startup? I have to open and close the software and then it goes.
    Any help would be good evey move of the mouse makes a whining noise and drives me nuts at the moment :mad:
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    Over the Hill & Far Away
    +137
    think its the power supply.. I have the same noise when I use the scroolwheel on the mouse.. does not bother me though...only hear it when its quiet :)
    I have a shuttle btw
    Matt
  3. mjn
    mjn
    May 24, 2001
    22,227
    Herts, England
    +10,059
    sounds like some interference from a faulty device.
  4. The Dude
    The Dude
    May 21, 2004
    6,337
    Beverley, East Yorkshire
    +2,692
    before you pop the lid off i'd try upgrading your soundcard drivers first, if that doesn't make a difference i'd try removing that TV capture card and see if that changes anything..
    looks like a faulty device as MJN says, but i've seen dodgy drivers cause similar probs before.. Even dodgy BIOS version can't be ruled out..
  5. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,623
    I remember having this problem - the problem is I can't remember how I stopped it. I know I didn't replace any hardware though so I'll have a think and post back if I remember. I have a logitech cordless mouse and an Audigy 2 sound card. I got noise through the speakers when I used the scroll wheel.
  6. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    :hiya: Thanks for your suggestions guys, I will have a look at the drivers first then check out the TV card.
    I can also hear the dvd drives too! Steady increasing whine as I burn one!?
  7. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,623
    I'm assuming you mean that you can hear the mouse through the speakers ? That is the kind of thing that was happening to me.
    I get a feeling that it was related to the CD Audio volume control - if I muted the CD Audio it got rid of the noise of the scroll wheel from the speakers. Eventually I disconnected the sound cable (not the IDE one!) that went from my DVD drive to the sound card and now I don't get the noise. I'mm 90% sure this is how I cured it.
  8. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    JohnG,
    Yes the noise is coming from the speakers!
    Thanks for the suggestion. I'll try that, I know the cable you refer to and I do have it connected. I am sure its the one that permits you to hear a cd straight from the drive by pressing the play button on it, so not going through the sound card.
    I'll let you know if it works!
  9. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    Hoorah!
    Spot on John :smashin: problem solved with the cd audio mute on!
  10. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    You should see the trouble i have with my mouse...
    [​IMG]
  11. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    Thanks Lynx but I said I heard it whining, not squeaking :D
