I am in cable hell!
Discussion in 'Projectors, Screens & Video Processors' started by pcavelle, Jun 11, 2003.
  1. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    I have (and need) multiple cable runs to my projector & it looks a right old mess.
    I need the assistance of a 'specialist' to lift the floorboards above the ceiling where the projector is mounted & run all the cables through so the whole thing is far neater.
    Can anyone recommend an organisation or an individual who would be able to do this for me?
    Paul
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Might sound daft but have you tried a quote from your friendly neighbourhood electrician? Well used to running cable and would find the job easy.
    Adding the initials 'cedia' or suchlike can add a zero to your bill....
    Regards,
    Ian Guinan
  3. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Yeah, an electrician would be able to do that for you no problem. You will need to take up the floor covering in the room above though, which may be a pain..
    But yeah - I can imagine that all the cable would be a nightmare running around the room! I'm lucky - my HC room is on the first floor, so I just ran the cables into the loft - nice and easy! :)
  4. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Wise words chaps. I'll put some feelers out.
    Paul
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,150
    UK.
    +2,670
    Have you thought about trying it yourself?
    A couple of big screwdrivers and/or bolster chissels will get many boards up, and if you need to saw them for aany reason, you can buy a special floorboard saw for about a fiver or so.
    It really is very simple if you look at it.
    Carpets will go back if they're held down with gripper rod too - just use the bolster chissel and a hammer.
    HTH
    Gary.
  6. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Paul,
    What part of UK are you in ?
    Mark.
  7. Supernosh
    Supernosh
    I just used some self adhesive trunking and run that just under the pelmet near the ceiling.
    Cost me about £40 for the lot and even the wifwas impressed at how neat and tidy it all looks (have put some up for all my five speaker setup!) and there are no wires to be seen.
    The best bit is that I am a DIY spaz and even I managed to do a professional job !!
  8. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Thanks for all the suggestions. I probably could do it myself if I set ½ a day aside. An added complication is that I need to remove some panneling from an RSJ too, so it's not mega simple really and I don't want to botch it up & shag the decoration etc
