I am having 2nd thought's. Panasonic Viera 37"
Discussion in 'Panasonic TVs Forum' started by Jed, Oct 9, 2004.
  1. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    I may be picking up my LCD on monday night,but i am hving second thought's.
    The price i am paying is £1620.
    The thing is how much better is the Panny Viera 37".
    I have heard glowing reports on these set's and £400 might not be as bad as i first thought.
    However i see that there is not as good a resolution as the LCD.
    How does the Panny fair with Terrestrial and DVD playback compared to CRT.
    I am sure i can change my mind before i pick it up on Monday.
    Your thought's please.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    pixels do not matter that much for video...... have a look at the thread by "theferiu" i have never met a disapointed veira owner but known a fair few who have returned 30" 32"LCD's for 37" Veira
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    It works for me :cool: :smashin:
    Even after two months viewing I'm still well chuffed with this TV. :) All I would say is that you must view before buying. Some people can see a slight flicker with Panny's 6th gen panel, i.e. Viera and PW6, however, most people can't.
    If you do a search on this section on either Viera or PE30 it should throw up lots of posts as there are quite a few Viera owners that post here.
    Here is the link that Horny mentioned about Thierfeu's experiences:
    http://www.avforums.com/forums/showthread.php?t=155314
    S.
    p.s. you have PM :)
  4. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Thanks for that DH and Steve.
    So DVD's are gonna be as good or better than my old 5 year old Sony. ?
    Terrestrial T.V. could be not as good.
    Don't forget that i am Cable and not Sky.
    Most of Cable is spot on at the minute on my CRT.
    I am just really worried that i am gonna end up with a lesser picture on something that cost's £1500 more.
    Know what i mean. :)
    Steve. Thanks for that review mate. Much needed.
    Jed.
  5. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Cable is a tricky issue and picture quality is more a post code lottery, i.e. more luck than judgement. I have read a few postings where people have been disappointed at their cable feed into their plasmas and others more than happy, thankfully I fall into the latter category. I read somewhere that if there are alot of subscribers on a street taking of a single feed then their PQ can suffer when compared to a street where only a few people are subscribed to cable. I can only assume that most people on my street have Sky or Freeview and not Cable as I find my cable viewing really great on the standard channels and only becomes a bit ropey on low bitrate channels like most of the shopping channels or stuff like FTN etc.
    S.
  6. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Another thing i have just measured.
    Our room is not very wide. It's actually not the best room for veiwing TV in to start with as we have to have our TV on a sort of fire Surround in a corner.
    I measured from the wall to the viewing area. That being 2.8ish :) metres. Depending on if i am lying down or sitting up :lol:
    If i need a stand, that will probably bring it down to 2.5 metres.
    Will both of these be too close.??
    Cheers Jed
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    2.5m is close.... but not necassarily too close to a 37" screen best go find one and take tape measure...
  8. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Dimensions as from Panny's Website for the 37" Viera:
    http://www.panasonic.co.uk/plasma-tv/th37pe30b/index.htm
    Dimensions (W x H x D) = 1040 x 697 x 99mm
    Panel only without pedestal stand or floor stand.
    *EDIT* :oops: misunderstood the question :blush: 2.5m does sound a bit close, as Horny said best try viewing at that distance in the shop, you may see all the dithering becoming visible at that distance and if so, it's not pretty viewing.
    S.
  9. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Cheers you 2. :)
    Gonna take my tape measure tomorrow.
    I am just hoping that although i have signed for finance, i should be able to back out if the TV is not here and box unopened.
    What do you think. Stupid me left the paperwork at work Bang Bang.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    where did you buy from Jed?
  11. thierfeu
    thierfeu
    anonymous plasma newbies session...
    - hello my name is thierfeu
    - helloooooo thierfeu
    - please listen my confession : as a newbie a considered resolution was the best way to have a nice and crisp picture. So for my money (3000€) i noticed 2 tv, on which I put my eyes samsung and hitachi sig sig ...
    - yessss thierfeu carry-on
    - well I came here and a horny dragon told me to have a look to panasonic, and...oh my god...ho it's so hard to say...
    - come on, we are your friends, we are like you..
    - Well I had to consider that the pana is really greater than the other ones : very precise color on skin, WONDERFUL blacks, nice contrast oh.. oh...with only 852 x 450 pixels
    -wouahhh
    - I my friends, and it's so beautiful whit it's stand ! apure diamond
    -yeahhhh
    - SO I have to announce my decision, considering I'm now cured, and before leaving : november 2nd, I will order a TH37 PA30 with stand, with 852 x 480
    i'm noooot a newbyyyye anyyymooooorreee !!!
    (standing ovation of the assitance) clap clap clap :clap: :clap: :clap:
  12. MrFurious
    MrFurious
    Sep 9, 2000
    15,020
    137
    Cardigan Wales
    +1,913
    chuffed with my viera now,at first it took time to get used to but now all is fine,just dont use dynamic mode!!one good example is that i watched thx1138 on it when i first got the tv,then watched thx again the other night after setting dynamic off and noticed something,in dynamic mode the opening credits scroll with white letters,once turning dynamic off i see that the credits should actualy be green!!!!!
  13. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Powerhouse mate. If i remember rightly HFC are the finance company.
    Cheers Jed.
  14. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Tierry Whooooaaaaaahhhhh Tierry Whoooooaaaaa. :)
    Horny Dragons eh. ;)
    Yep i read with interest your thread. Good reading it was too,
    Cheers.
    MC You got one of these beastie's have you. Well depending on the next couple day's we might be trading tips. :)
    Jed.
  15. thierfeu
    thierfeu
    just saw the match vs ireland : CRAP blue team, Crap blue supporters (there was 35000 Irish supporters in "le stade de france" making more noise than the 60000 others)
    do you think there is a special tuner on Panny¨Plasma to make France play football as well as before ? Dooh ! sig sig I want Zidane back (don't you ? :D :devil: :offtopic: )
    Well I go to sleep with my eternal problem : size
    :lesson: : Hey Thierry your armchair is 3m from the TV set, a 37' Panny with stand is enough for you
    :devil: : hey boy, don't listen this chicken !! for the same price take the 42' and a ikea stand. 37' will be too small for you in 6 months
    :lesson: : Yes Thierry but your wife will shout like a furious goose when she see the TV size and not assorted with stand
    :devil: : no problem, let her shout, women always shoot. take the 42, boy !!
    :lesson: : you'll regret, sure ask my friend hornydragon...he has always the best answer
    :devil: : grrr ! I hate dragon
    Well : 37' or 42' inches that is the question (considering it should be 37' in fact) 20 days to make my mind (but I swear stopping flooding with the same question from now :spam: )
    Bonne nuit gentlemen !
  16. peezee
    peezee
    3m me semblent un recul suffisant pour un 42"... Maintenant ça dépend, tu tiens vraiment à ta WAF? :devil: (j'déconne of course! ;) )
    Transl: 3m distance seems enough to me for a 42" screen; now it depends, do you really care about your WAF? :devil:
  17. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    When seagulls follow ze trawler, it is because they think sardines will be thrown into ze sea. As quoted by Eric Cantona :D
    So my friend. Your saying that 3 metres is good enough for a 42" :)
    Jed.
  18. thierfeu
    thierfeu
    héhé lool Eric cantona : one of the greatest french philosoph, (incl montesquieu, voltaire, bergson) :lesson:
    with Anelka, you may be quiet, he will not deliver sentences like this one....he never speaks
    considering the distance : my problem is : 3 m is either good for 37 AND 42 inches 42 is just wider... :confused:
    "When seagull want to watch TV they prefer the 42 inches, because they think they can stay higher..."
  19. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    :laugh: :laugh:
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the actually diffeence between 42 and 37 screen sizes is very little as they are measured diaganolly........
    42" 1140 x 757 x 99mm
    37" 1040 x 697 x 99mm
    Whats 100mm between man and wife?????? ;)
  21. laurence harvey
    laurence harvey
    probably devorce if it goes the down 100 mm instead of up !!!!!! :devil:
  22. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Good news and bad news.
    First the bad. My LCD will not be coming in till Wedensday. :(
    The Good news.I have 7 days home approval. If not satisfied i can pick from the shop.
    They had a Panny 37" Viera for £2999 but they will pricematch anything that is not WEB based only.
    So i can still go to Sound & Vision and LE conecpts. :) which will get it down to £2199 Anybody know any better. :)
    Oh and took my measurements with me.
    The 37" looks fine to both me and the wife. :D even down to 2.3 metres where i usually sit on the floor.
    Oh and the picture was Lord of The Rings and it looked outstanding.
    Cheers guys.
    jed.
  23. Andy C
    Andy C
    Jul 14, 2004
    119
    16
    Krish AV have the 37PE30 in stock for £1999. They also have a real shop so you should be fine.
    http://www.krishav.co.uk/store/prodView.asp?idProduct=952&idCategory=496
    I'm trying to get John Lewis to price match it for the 5 year warranty. :)
    Andy.
  24. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Well spotted mate. I have kept that link.
    I have already scoured the internet. ? Is it worth me looking anymore. :)
    http://www.digitaldirectuk.com/products_moreinfo3/index.asp?product_id=4127
    This is the cheapest i can find but alas it does not look like they have a shop :(
    Jed.
  25. gcgoldchristoph
    gcgoldchristoph
    Hi Andy
    Wondered if you have had any joy with getting JL to price match with KRISHAV. Thinking of trying to do the same to get the famous 5 year warranty
    :D
  26. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Yep another one on the lookout for this.
    Is it worth taking in a Magazine to hurry them up. They can ring them up there and then.
    The last time i did it via the net it took about 5 day's.
  27. Andy C
    Andy C
    Jul 14, 2004
    119
    16
    I phoned the Kingston (my closest branch) store last Thursday. They said they would let me know by mail and as yet I haven't heard back. You guys will be the first to know if I get a yes or no. :)
    Andy.
  28. Andy C
    Andy C
    Jul 14, 2004
    119
    16
    I heard back from JL today regarding my price match query...
    Apparently KrishAV charge £40 for delivery, so John Lewis have agreed a match for £2039. Still a good price so I'll be placing my order very shortly. :D
    Andy.
  29. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Great result Andy.
    I am going to go in the Newcastle branch today armed with my What HiFi and Video book.
    Cheers jed
  30. Tejstar
    Tejstar
    Dec 4, 2002
    22,834
    London
    +1,094
    Does this include stand & recorder?
