I am confused, can you help me which reciver?
Discussion in 'AV Receivers & Amplifiers' started by petarst, Nov 26, 2004.
  1. petarst
    petarst
    Hi to all,
    Now i am really confused what to buy?
    I have a Monitor Audio Silver series speakers with S8 fronts and S1 at the ends and etc....
    I had a Denon 1804 reciver ,but i sold it because it can't drive my S8.
    NOW i don't know what to buy.
    I have a dilemma DENON 3805 , NAD T773 they cost me here in Belgrade 1200 euros.
    Or should i consider Yamaha 2500 or Pioneer AX5i ?
    Or sholud i take 2105 Denon with c 272 NAD AMP?
    PLEASE HELP :confused:
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    I used to drive monitor audio silver speakers with a nad t752 receiver and they sounded superb.I would go with the nad T773 if i were you,Great in stereo and movies and its got loads of power.I would have brought nad again if the harman kardon avr8500 had'nt been available.
    Cheers Gonzo.
  3. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    I concur, the NAD T773 should be more than adequate.
    You could look at the Pioneer 2014, Yamaha RXV1500 or Arcam AVR250 as well.
    I would have suggested the Marantz SR8500 as well, but it seems that you are in a hurry, and the SR8500 is not yet released.
  4. petarst
    petarst
    Thx people,
    Because NAD gives us here in Serbia special discount i will order a T773 and I think that i will be very satisfied with it. :thumbsup:
