Hyundai vs Neovia
M
mattygg
Hi all,
I was looking at getting the Hyundai 4250 plasma screen, but i have just come back from curry's and i saw a Neovia NEOPL4200 which looked pretty good in the shops. I have checked the reviews and the Hyundai got 7/10 which seemed pretty good to me, there is no review of the Neovia one. They are both priced at £999.99 which is about my budget, i was wondering if anyone had any advice on these two plasma's.
Thanks in advance
Matt
Shimmyhill
Is the Neovia the same one as PCW sell ?
If so i was speaking to a m8 who works there and they said that they went bust and only display models are avaliable. The one i saw looked pretty poor imo.
(this could be wrong if i have the make mistaken)
M
mattygg
I couldnt see it on the PCW website, but i think currys and dixons and pcw are all owned by the same company so who knows.
M
mattygg
I have found another tv Goodmans GTV42P which looks ok, does anyone know if this is any good?
Matt
Mep
Personally Matt I would recommend saving up a bit more and going for a proper name plasma such as a panasonic or pioneer fro example. I can tell you from personal experience that the budget route is not the way to go! Are you loking for a tv (i.e. with built in tuner and speakers) or a panel that you wil be connecting sky/dvd to with a surround sound system?
M
mattygg
I will be buying sky + when i move in, along with a dvd home theatre system, prob a 6.1 or 7.1. What about the hyundais imagequest, i have found one of these for 999.99.
cheers
Matt
mickymcd
If you stretch another £100 squid mate go for the relisys from ebuyer £1098 2 year warranty speakers and stand loads of connections hidef compatible its pic is far better than my mate pioneer and my neighbours panasonic
[/IMG]
[/IMG]
[/IMG]
I have just inputted hidef stuff from pc through dvi too picture is jaw dropping also picture from ntl and freeview spot on i was going to get the hyundai imagequest but when i seen the relysis it won me over the contrast well better no gosting on footie no lip synch dead pixels noise etc very good unit cant go wrong
Trending threads
