I had a good look at the Hyundai in Comet the other day. It was displaying Ice Age (seems to be popular with plasma demo's) and looked absolutely fantastic. Really!!! The only thing was that the on screen menus are a real pain to use, and it only has 1 scart.
I'm probably going to buy this one or the Techwood. Not sure. The Techwood has 4 scarts (2 RGB) and I need to connect a Telewest box, PS2 and DVD player, none of which have component output, but the Hyundai does have component for future upgrades... hmm Anyone recommend a good scart multiplexer or scart>component converter.
Both also have DVI and D-SUB so equal there.
Has anyone here bought the Hyundai or Techwood recently? I know from a search on this forum that there are opposing opinions on the Techwood, however when I spoke to the salesman in Currys he said that the new ones say "Techwood by LG" on the box and I have to say that the picture quality looked great to me.
Specs on these are really hard to find. Does anyone know if they have any anti-burn settings?
The other issue is that some web reviews/comments say that these panels are not progressive scan.
I thought all plasmas were progressive by design, sort of like saying that some LCDs aren't progressive.
Finally, although the general consensus is to buy the Panny 42PWD6, I reckon this could end up a tad on the expensive side after you've bought the connector boards you need. Any advice?
Both the Hyundai and Techwood are now £1799.00
P.S. Apologies for reviving an old thread (at least I brought it back on topic!!) and OK this may be a bit long for my first post.
