Hyundai ImageQuest HQP421SR 42" Plasma
Discussion in 'Plasma TVs' started by elite_uk, Jul 31, 2005.
  1. elite_uk
    elite_uk
    Jul 30, 2005
    60
    Hyundai ImageQuest HQP421SR 42" Plasma Price: £894.95 (£1,051.57 Including VAT at 17.5%)
    Hyundai ImageQuest HQP421HR 42" Plasma Price: £1,174.95 (£1,380.57 Including VAT at 17.5%)
    Are these good screens for tv or just pc? or am i better off getting
    Samsung LE32R41BDX
    or an
    Hitachi 32LD7200
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,814
    71
    birkenhead
    +73
    do a search.
  3. nicknackynoo
    nicknackynoo
    I have the SR version and it performs just fine. It has twin tuners and plenty of connections for DVD, PS2, Sky and computer and has a DVI connection too.
    If I had the choice again I'd go for the HR (high resolution) version for obvious reasons.
    The instruction manual is a bit of a joke as its badly translated, but there isn't anything too complicated to do with it anyway.
    I got a mounting bracket from the Vogel range no problem but the mounting bolts on the rear of the plasma were too short, luckily Vogel include a selection of bolts with the bracket and this worked fine.
  4. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    i didn't find any reviews on HR version as well, so if you know where they are, please let me know.
  5. nicknackynoo
    nicknackynoo
    You can find them right here on av forums:
    Go to 'home' then 'features', hit the box for hardware reviews you will be prompted to pick an equipment type (in this case plasma displays) and you can also type in the make and model, just type in hyundai as this will do.
  6. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    Well, as i said, there are no reviews for HQP421HR (and Fujitsu Myrica P42-2) as well....
  7. nicknackynoo
    nicknackynoo
    Yep, my error I thought you meant any Hyundai review. But you can read those reviews, its the same set but with better resolution.
  8. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    I doubt that.
    I think Hyundai is using diferent suppliers for SD and HD plasma's...
  9. CoolCurly
    CoolCurly
    Jun 10, 2005
    573
    43
    +104
    Hyundai have not been able to get a review of the HR version done as yet, but will be shortly.
    If anyone reading this works for any reviewer, I would be interested in sorting something out for the UK..
    There are new models being launched after the Big AV show in Berlin, and again products will be reviewed as soon as possible.
