HYUNDAI HPTN4200S 42" *NICAM* SILVER
Discussion in 'Plasma TVs Forum' started by NMR, Aug 6, 2005.
  1. NMR
    NMR
    Aug 6, 2005
    156
    Bradford, West Yorkshire
    Purchased one of these from QED-UK.COM. Arrived, and was all good. However, when switched on it made quite a loud buzzing noise which came from the back panel.
    QED UK arranged for a replacement to be delivered, (today), however the buzz is still there (albeit not as bad)
    Is this :-
    1) Another faulty set
    2) A noise which will disappear when I put some hours onto it
    If anyone else has had the same problem, or can help with some further info, I would be grateful
    Cheers !
  2. NMR
    NMR
    Aug 6, 2005
    156
    Further to this, I have seen the same model in Comet and it is quiet, no noise.
    Do I need a 'line conditioner',??
    Anyone help? :lease:
  3. CoolCurly
    CoolCurly
    Jun 10, 2005
    573
    46
    +104
    This is a different part of Hyundai that OEM panels.
    If you want the better quality, HQP421SR is the one to look for.
