HYUNDAI HPT-4240 anyone own one
Discussion in 'Plasma TVs' started by hornydragon, Jan 2, 2005.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    a mate of mine has just ordered one of these for £999 from powerhouse and as such has asked my advice on setting it up..... Delivered next week so have a 4 days to prepare but does anyone already own one? particukary interested in the S-vdieo preformance
    For £999 they look OK (spec wise) I just hope and pray that they reliability is better than TINY............Proof will be in the picture tho.....
  2. eatonluke
    eatonluke
    Jan 2, 2005
    59
    hi bud i don't know if its the same as the hyundai 4240, its ok on a scart lead but do u think it might be better on some form of other lead as i am new to plasma. only had it 2 days, thank's about the code u told me 2 put in but it did not work and sky say they might have the remote code for these tv's soon or may be not (nice one)
  3. eatonluke
    eatonluke
    Jan 2, 2005
    59
    sorry for other post i thought you said it was a hyundai 4250, but iam on about the 4240 above
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    thanks have you tried S-video? as i am interested in this pricularly
  5. freeman
    freeman
    Dec 27, 2004
    240
    +11
    Not really very impressed with s-video myself slightly worse than scart ,Pal not RGB I guess.
    I've got my Sky+ box connected through a scart sync separator to the anolog RGB (VGA)input,my DVD by component & when I get a DVI cable my computer to the Digital RGB input .
    I was going to buy one when I was out ,but the only place that had them was PC World & they wanted £50 for a DVI cable :eek:
    I'm really happy with mine :thumbsup:
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    that is a pity... which scart seporater are you using? also interested in the results of DVI especailly if it will accept WS resolutions a looking at the manual they are all 4:3
  7. freeman
    freeman
    Dec 27, 2004
    240
    +11
    This one
    The DVI picture is very good ,but as yet I can only get 4:3 resolutions.
    Microsoft don't seem to have drivers for widescreen plasmas,but reading their website it sounds like Windows XP Media Center Edition may be what we need .
    Could Microsoft be trying to make us spend more money do you think?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    try using pwerstrip to set 1920x1080 or or 1366x720 it may be the Hyundai will only take 4:3 signals via VGA or DVi inputs... (try WXGA on PC) thanks for the input mate but i think this might be the stubling block.....
  9. freeman
    freeman
    Dec 27, 2004
    240
    +11
    I've now updated all the drivers for my graphics card & the lastest CATALYST control centre software & now I can get proper widescreen windows :thumbsup:
    My computer now identifies my pdp as a pdp ,not just a monitor as it did before :clap:
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    does it look good? and are you using the PC for DVD does it look anygood.....DVi or VGA???
  11. freeman
    freeman
    Dec 27, 2004
    240
    +11
    It looks wonderful :smashin:
    I was using it for "return to castle wolfenstein" + some av files on my computer.
    DVI connection :thumbsup:
  12. eatonluke
    eatonluke
    Jan 2, 2005
    59
    Hi bud i have now put my dvd into component 1, it is sh** hot , as for sky+ i have done with a scart, i would say its about 90% sh** hot. all the lead are gold plated. As for the sky+code for this tv, it is 0634 if thats any help for when your mate gets one.
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    thanks freeman and eatonluke
  14. wilfred
    wilfred
    Guys,
    I'm looking to buy one of these, but wanted to check with someone who already has one if it has fans, or is fanless? Older plasmas which have fans can be very noisey otherwise.
    Thanks, Wilfred
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    wilfred the price of plasma has tumbled.....LG PX11 is now £1250 and Panny PWD6 £1099 PW7 £1300............are you sure you still want a hyundai?
  16. wilfred
    wilfred
    Thanks for the info HornyDragon, but whereabouts have you seen these prices?
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    PWD6 was 1099 at richersounds LG is at £1250/£1300 at a few places (JL will price match some so get 5 yr warranty) PW7 prices were £1300 with input board but stock has gone and prices now gone back up......... see here for how to get an LG for £1300 and 5 yr warranty http://www.avforums.com/forums/showthread.php?t=202150
