Hyundai HLT 3290 - any views
Discussion in 'LCD & LED LCD TVs' started by brooon, Sep 8, 2005.
  1. brooon
    brooon
    I am looking to buy the above panel from Komplett. Does any one have this panel or have any comments on it.
  2. jtorry
    jtorry
    Nov 8, 2001
    520
    I mailed komplett about this set and got the following response.
    If it is HDCP enabled then it is a cracking price.
  3. brooon
    brooon
    I mailed them about a few things regarding the panel. They didn't seem to know much.
    They did say it came with a 3 year warrenty though.
  4. CoolCurly
    CoolCurly
    Jun 10, 2005
    573
    43
    +104
    This Hyundai panel comes from another side of Hyundai (Hyundai Corporation) who dont actually manufacturer ANY panels but have them badged by cheap factories. The quality is far lower then the offerings from Hyundai ImageQuest (www.hyundaiq.com) who actually manufacturer and develop technologies.
    Same name, but two entirely different companies.
  5. brooon
    brooon
    Take a look at the quote fro Komplett's website
    As you can see Image quest is mentioned?
  6. CoolCurly
    CoolCurly
    Jun 10, 2005
    573
    43
    +104
    www.hyundaiq.com
    I'll give you £100 if you can find that model listed.
    Komplette are currently not supplying the Imagequest range of panels, but I will break them down..
