Hyundai 4240 Plasma codes
Discussion in 'Plasma TVs Forum' started by rs2600, Jan 10, 2005.
  1. rs2600
    rs2600
    Trying to get the TV code in order to activate a universal remote control so I can minimize the number of remotes. Should be a 3 or 4 digit number,
    Thanks,
    Mats
  2. eatonluke
    eatonluke
    Jan 2, 2005
    59
    Bud try 0634 or try to manual find code on your remote this will work for sure, it will tell u in the remote manual how to do this, but the code i have just gave u should work it, it does on mine fine. What do u think of you 4240 as i have one and i would give it about a 90% rateing, not bad for a £1299.00 plasma.
  3. rs2600
    rs2600
    Thanks, I'll try that. I would say that You don't get anything better for the money. Over here in Sweden it was on sale for £1165.
    Mats
  4. eatonluke
    eatonluke
    Jan 2, 2005
    59
    cool price
