HYUNDAI 32" Widescreen LCD HDTV Monitor..Please Help.
Discussion in 'LCD & LED LCD TVs Forum' started by Pr3vaiL, May 25, 2005.
Tags:
  1. Pr3vaiL
    Pr3vaiL
    I need advice ASAP. Im looking for an LCD and I need to buy it before Friday. I found this 32" LCD for $1200.00. Here is the link. I will use the TV for XBOX GAMING. WHat are your thoughts?
    http://www.walmart.com/catalog/prod...996&type=19&dept=3944&path=0:3944:133276:3996
    # Hyundai 32" Widescreen HD-Ready LCD TV, HLT-3270 brings big screen drama to any home
    # 32" LCD panel from LG
    # Sleek desktop stand easily removes for wall mounting
    # Wall-mountable with integrated stereo speakers for a clean, simple look (Wall-Mount kit sold separately)
    # Aspect ratio: widescreen 16:9
    # HD-ready; requires a set-top box (purchase separately) to decode the high definition broadcast signals
    # Resolution: 1366 x 768
    # Brightness: 500 cd/m2
    # Contrast (CR): 500 : 1
    # View angle: 176 degrees
    # Audio Out put ( RMS ) 10W x 2CH
    # Tuning: NTSC
    # Progressive Scan feature works with progressive (480p) scan DVD players to display movies in the best quality possible
    # Interfaces: 1- S-video in, 1- PC In (D-SUB 15Pin), 1- Component in, 2- Composit A/V in, 1- NTSC RF in (Antenna or cable input), 1- DVI in
    # Digital Signals Supported: 1080i, 720p, 480p
    # Multi-language OSD
    # Picture-in-picutre
    # Convenience features: Sleep Timer , On/Off Timer
    # Comb Filter 3D Digital Comb Filter(NTSC Only)
    # Dimensions Without Base Stand:36.4"W x 3.8"D 19.3"H
    # Dimensions Including Base Stand: 36.4"W x 10.4"D x 21.5"H
    Thanks in advance!
    Cheers.
