Hyundai 32" LCD-TV HLT-3290 £699
Discussion in 'LCD & LED LCD TVs' started by jtorry, Aug 29, 2005.
  1. jtorry
    jtorry
    Nov 8, 2001
    520
    Just saw this when looking at komplett. Claims HD ready and does have DVI-D.
    details here
    Connector Type
    1 x VGA input ( 15 PIN HD D-Sub (HD-15) )
    1 x DVI-Digital ( 24 PIN Digital DVI )
    1 x S-Video input ( 4 PIN mini-DIN )
    1 x audio input ( mini-phone stereo 3.5 mm )
    1 x component video input ( RCA phono x 3 )
    1 x SCART (RGB) ( 21 PIN SCART )
    1 x SCART ( 21 PIN SCART )
    Can't seem to find any other info on this set though.
  2. jtorry
    jtorry
    Nov 8, 2001
    520
    anyone have any info on this set?
  3. vipergrm
    vipergrm
    Sep 6, 2005
    3,745
    Belfast
    +565
    I am looking for details too! Just came accross this myself. I can't even find a Hyundai website other than the car one. If that is the case I am not touching it. Actually, if you phone Komplett they are normally very helpful with providing information. They might be able to e-mail the full spec or something. Worth trying :thumbsup:
  4. Chris94
    Chris94
    Have a look at http://www.hyundaiq.com/
    I couldn't find the Hyundai HLT-3290 listed, maybe it's an old model ?. Anyone have any opinions about this TV ?
  5. vipergrm
    vipergrm
    Sep 6, 2005
    3,745
    Belfast
    +565
    I phoned Hyundai from the above site and spoke to a very helpful German guy, although the language barrier was a bit tricky. I'm sure he said it was the same spec as the HQL320WR but to be sure, I e-mailed their info desk like he asked me to do and said that they would respond with a specfication. If that is to be believed, then the following specification applies...
    Full Specification
    General
    Product Type
    LCD TV - color
    Width
    95.7 cm
    Depth
    9.5 cm
    Weight
    15.7 kg
    Height
    49.5 cm
    Television
    Technology
    TFT active matrix
    Diagonal Size
    32" - widescreen
    Resolution
    1366 x 768
    Image Aspect Ratio
    16:9
    Widescreen Modes
    Conventional 4:3, Auto Wide, Zoom, Normal, Panorama, 16:9
    Additional Features
    Video noise reduction, auto power off, on-screen menu
    Image Contrast Ratio
    1000:1
    Viewing Angle
    170 degrees
    Color Temperature Control
    Yes
    Brightness
    450 cd/m2
    Pixel Pitch
    0.51mm
    Picture Adjustment
    Standard/Natural/Mild/Sport/Custom
    Pixel Response Time
    23 ms
    Backlight Life
    50,000 hour(s)
    Color Depth
    24-bit (16.7 million colors)
    Viewing Angle (Vertical)
    170 degrees
    Max V-Sync Rate
    75 Hz
    Max H-Sync Rate
    61 kHz
    TV Tuner
    Tuner Qty
    1 tuner(s)
    Multi-channel Preview
    Picture-in-picture (PIP)
    Video Features
    Parental Channel Lock
    Yes
    Freeze Memo
    Yes
    Remote Control
    Type
    Remote control - infrared
    Audio System
    Sound Output Mode
    Stereo
    Speakers Included
    2 speakers
    Speaker(s)
    2 x right/left channel speaker - built-in - 5 Watt
    Additional Features
    Auto volume adjustment
    Output Power / Total
    10 Watt
    Equalizer
    Yes
    Sound Effects
    SRS WOW
    Connections
    Connector Type
    1 x RF input ¦ 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) ¦ Composite video input ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 1 x component video input ( RCA phono x 3 ) ¦ Audio line-in ¦ 1 x headphones ¦ 1 x composite video/audio output ( RCA phono x 3 )
    Power
    Power Device
    Power supply - internal
    Voltage Required
    AC 110/230 V ( 50/60 Hz )
    Power Consumption Operational
    140 Watt
    Power Consumption Stand by / Sleep
    3 Watt
    Miscellaneous
    Cables Included
    1 x coaxial RF cable
    Compliant Standards
    DDC-2B
    Dimensions & Weight (Shipping)
    Width (Shipping)
    107.5 cm
    Depth (Shipping)
    32.8 cm
    Height (Shipping)
    67.4 cm
    Weight (Shipping)
    23 kg
    Filter-Number
    Header / Packaged Quantity
  6. vipergrm
    vipergrm
    Sep 6, 2005
    3,745
    Belfast
    +565
  7. brooon
    brooon
    The spec that you recived is different to the one on Komplett's website.
    As you can see it states it has DVI..and a few other differences..
    The spec that Komplett have is exactly the same as the HLT 3270 model
    that power house are selling for ~£1200..
  8. CoolCurly
    CoolCurly
    Jun 10, 2005
    573
    43
    +104
    Hyundai ImageQuest (which is www.hyundaiq.com) is a different company from the Hyundai Corp that produces the HLT-3290.
    The main difference being that Hyundai ImageQuest actually manufacturer, while Hyundai Corporation use factorys to OEM product (lower grade panel, lower service levels and to be totally honest lower quality product).
    The product that the German guy has spec'ed you is available from many leading E-tailers at the moment.
