Hydravision Help
laff2k
Tried a search with no luck?
Have a q about Hydravision.
I have set up my Z2 thru DVI [as the secondary display] and the TFT thru VGA as primary. Works fine and I can set different res for each etc. However...
When I run PowerDVD or WinDVD the playback is jerky. Noticeable on camera pans etc. If I kill Hydravision and set the Z2 as the only display, DVD's [or DVD files from HD] play just fine.
I have both DVD players set to use Hardware acceleration and my CPU runs as high as 46%. The problems get worse if I open another app on the TFT, say browsing the web or reading mail.
Is this a hardware issue or am I missing something?
HTPC:
Radeon 9700 Pro
P4 2.4Ghz
512Mb RAM
XP Pro
Steve:confused:
SeaneyC
What frame rates are you running?
My system stutters like mad when set to anything other than 50hz (for PAL material, i don't have much else at the moment)
