I noticed the problems that everyone is having with a Blackgold PCI-Express card and Vista not coming out of sleep mode correctly.
I have the PCI single tuner DVB-T card and the same problem on Vista Ultimate.
Spec as follows
Gigabyte GA-K8NF-9 board
AMD 64 3200 cpu
Sapphire Radeon X800GTO2 graphics
1GB Crucial ram
Hyper 425W PSU
Goes into hybrid sleep no problem and starts back up ok if no recording is scheduled.
But if a recording is set, it might start up and record the first, then might or might not go back to sleep and will never record the second programme.
I've gone through all the power settings, hybrid sleep is enabled, installed a fresh copy of Vista with S3 set in the Bios. All drivers are up to date for motherboard, graphics and latest Bios on the motherboard, still will not work correctly.
Has anyone any suggestions?
E-mailed GTA about the tuner card but no reply back.
Spec as follows
AMD 64 3200 cpu
1GB Crucial ram
Hyper 425W PSU
