Hybrid LNB
Discussion in 'Satellite TV, Sky TV & FreeSat' started by winston2010, Dec 3, 2017.
Tags:
  1. winston2010
    winston2010
    Jun 28, 2010
    1,920
    London
    +201
    I've asked this elsewhere but got no response so:
    Does anyone know how a hybrid LNB can detect whether a Q box or normal box is connected? I assume it defaults to normal mode unless a Q box is connected. If so this must mean the Q box must send some sort of signal. Anyone know?
  2. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Could it be down to voltage on cable
  3. winston2010
    winston2010
    Jun 28, 2010
    1,920
    London
    +201
    Maybe, but does a Q box use different LNB voltages? It could also be some sort of tone signalling but does anyone actually know how it works?
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,627
    Redditch
    +4,208
    A Sky-Q box outputs 12V (it's in the box spec). A standard universal normally has a minimum output of 12.5V when using vertical polarisation and 15.5 when switched to horizontal. Whether the 0.5V is enough to tell not sure. I would have thought a long coax run would confuse the lnb.
    There's no band or polarisation switching on a Sky-Q lnb. The IF used is lower and allows all Low Band and High Band vertically polarised transponders to be carried on one cable, and all the horizontal on the other.
    A standard universal only has a tone when it needs to access high band transponders.
    A standard Sky-Q lnb only has two outputs.
  5. winston2010
    winston2010
    Jun 28, 2010
    1,920
    London
    +201
    That is all straight forward. Obviously a Q LNB has dedicated H and V outputs and a Q box has dedicated inputs. Can see some confusion with getting the cables the wrong way round but assume installers would notice if it was wrong.
    Back to a hybrid LNB. I understand any 2 outputs can be used with Q. Are some outputs dedicated H and some V? If not how does the LNB know? I don't think 12v as against 12.5v is enough to differentiate with a standard receiver. I wonder if it is possible to use 2 Q receivers on 4 outputs (not that that would be necessary as with no voltage/tone switching simple passive splitters can be used).
    There seems to be no information at all on any of this.
  6. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,370
    Reading
    +435
    The outputs of the LNB do not appear to be dedicated, I assume the Q box inputs are.
  7. winston2010
    winston2010
    Jun 28, 2010
    1,920
    London
    +201
    OK, so how does the hybrid LNB know which output to send V and which out to send H to a Q box and how does it know a Q box is connected rather than a standard box?
  8. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,370
    Reading
    +435
    You can connect a Q box to any of the six outputs so it must be the box inputs that are dedicated to H & V.
  9. TJT1
    TJT1
    Jul 29, 2011
    4,836
    East Sussex, UK
    +1,141
    But that still does not address the OP's question.
  10. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,370
    Reading
    +435
    Well if you know better....
  11. TJT1
    TJT1
    Jul 29, 2011
    4,836
    East Sussex, UK
    +1,141
    No, I don't, :(but at least I understood the question, and am interested in the real answer as it seems a bit puzzling how it's done:D
  12. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,370
    Reading
    +435
    I understood it also, I answered what I though was possibly correct and did not answer what I don't know.
    I'm sure the OP could find the answers using a search engine. After all it just Sky's propriety version of the technology.
  13. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,627
    Redditch
    +4,208
  14. Antsue
    Antsue
    Nov 15, 2017
    Norwich
    Sorry as I'm 71 and not that up on tech can someone tell me in plain info why the q box works and the sky plus hd box works both from the hybrid lnb.As the sky plus hd box must be useing the same signal as the standard lnb but the Bush box can't see anything yet it's advertised that if you have an ordinary sky box i.e. hd you can just swap them round as that is what I did i.e. Bush for hd box but got no results
  15. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,370
    Reading
    +435
    What Bush box?
    I use a LG OLED TV and Ferguson HD satellite box both work fine on the hybrid lnb, as do occasionally a Goodmans, Humax and Openbox satellite receivers, all with currently with a Sky Q also connected.
  16. Antsue
    Antsue
    Nov 15, 2017
    Norwich
    Bush hd 500gb
  17. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,370
    Reading
    +435
    You need to be specific that could be a Freeview receiver!
  18. winston2010
    winston2010
    Jun 28, 2010
    1,920
    London
    +201
    Indeed. But as I said in your other post:
    "Perhaps the hybrid LNB does not recognise your Freesat box for what it is. No one seems to know how a hybrid LNB determines what is connected to it."
    Until we find out how a hybrid LNB knows what type of box is connected to it, it will remain a mistory.
  19. Antsue
    Antsue
    Nov 15, 2017
    Norwich
    Bush 500GB FREESAT+HD DIGITAL TV RECORDER BUT I THINK I MIGHT SEND THIS BACK AND TRY A HUMAX 1100s
  20. JayCee
    JayCee
    Jan 20, 2004
    24,002
    Lanarkshire
    +2,618
    That's it's description.
    The model number will be printed on a label probably on the bottom or rear of the box.
  21. Antsue
    Antsue
    Nov 15, 2017
    Norwich
    Sorry about that I've sent it back this, morning will try something else silly really all because sky won't let you run its plus box beside the q box only as a locked free sat and the wife uses it around the house to watch her soaps in different rooms as she dose what ever it is wives find to do
