Hybrid bike for £400?
Discussion in 'General Chat' started by gchildx, Aug 5, 2013.
  1. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    Hi. Looking to get a bike on the work scheme. Got a voucher coming soon, but not sure what bike to get. Complete new area for me.
    Mainly will be road and light off road/path for commute to station mainly.
    The shortlist so far is as follows:
    - specialized sirrus
    - giant escape 2
    - boardman performance hybrid race bike
    - carrera gryphon
    Will need an XL frame.
    Thoughts?
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,181
    +7,321
    You'll probably get more exposure posting in this thread.
  3. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    Thanks for heads up.
  4. IanW1977
    IanW1977
    Dec 30, 2002
    4,585
    West Midlands
    +484
    All Year round commuting or just a fair weather commuter ?
  5. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    Fair weather for now, at least until confidence builds up.
  6. IanW1977
    IanW1977
    Dec 30, 2002
    4,585
    West Midlands
    +484
    Do they all have disc brakes?
  7. arenaman
    arenaman
    Nov 13, 2009
    8,386
    +6,931
    Get a 2nd hand one off the bay instead, I got a £1k Cannondale Synapse 105 Flatbar for £400 and it's fantastic for my needs. If you need to get new I had the boardman for about a week, it was a nice bike for the money.
  8. xox Godders xox
    xox Godders xox
    Jan 2, 2008
    1,421
    +316
    I don't think your average ebay seller accepts cycle2work vouchers. ;)
    Personally having commuted on all sorts of bikes for several years I would recommend a road bike (albeit one that'll take mudguards). Don't know if there's scope to up the budget or add your own funds to the voucher but the Boardman Road Sport looks like great value at £500.
    If your set on a hybrid I don't think you can go wrong with the Boardmans really (just make sure you budget for a wicker basket and a cape! :D).
  9. Yoggo
    Yoggo
    Aug 23, 2006
    195
    Worcester Park
    +15
    I got a Specialized Sirrus Elite Disc on Ride to Work for £750, got that model for the better frame + hydraulic disc brakes. Pretty rapid, not great on bad surfaces though thanks to high pressure tyres + rigid frame.
    Plenty of mounting lugs for guards/panniers/etc., the brake calipers are out of the way so shouldn't effect mud guard mounts.
    I got a large frame (I'm 6'0 but only 31" inside leg), the saddle is pretty low so just about enough clearance on the top tube but needed the large frame for my long arms, tried a medium and it was too uncomfortable.
    Where can you get your bike from? We have to use Evans so could not look at Boardmans. Did try a Hoy though which was better spec than the Sirrus but it just didn't fit me right.
  10. IanW1977
    IanW1977
    Dec 30, 2002
    4,585
    West Midlands
    +484
    If it was all year round for me and just 1 bike I'd get a road with disc brakes but if fair weather a road bike with rim brakes.
  11. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    Hi. Voucher has to be used at halfords, but they can source any bike from independents network.
    Because I'm 6'3" the sales rep suggested a boardman would be too small as only go up to a large. Still tempted by it , looks great in the metal.
  12. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,181
    +7,321
    Would be worth finding a store with one in stock to try.
  13. xox Godders xox
    xox Godders xox
    Jan 2, 2008
    1,421
    +316
    I find it hard to believe that you couldn't set up the largest Boardman frame to fit someone your size. 6'3" is tall but not freakishly tall!
    Halfords staff are a bit hit and miss when it comes to knowing what they're talking about unfortunately (we are talking about a shop that's been known to sell bikes with the fork on back to front after all!).
  14. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    You're probably right. The sales rep said something about the bar that runs between the handle bars and seat being at least 3 inches below crotch and got his tape measure out. Not sure what he was measuring but concluded it wasn't for me. I just thought that the seat and handle bars could be adjusted upwards to compensate. I might try another store to see if there is a different opinion.
  15. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,181
    +7,321
    I think that sort of clearance is more for mountain biking where you may leave the saddle unexpectedly & with great momentum. For normal road use 1" clearance should be enough.
    As I said, you really need to sit on one as there's more to it than just your height.
  16. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Ooh, suits you Sir! :laugh:
  17. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,181
    +7,321
    I thought of this:
    [ame=http://www.youtube.com/watch?v=Bp6IApV9lwE][HD] Friends - Joey's Tailor - YouTube[/ame]
  18. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    Ha ha. What a good show that was!
  19. gchildx
    gchildx
    Mar 8, 2007
    124
    London
    OK, my voucher has come through. Any further thoughts on the selection of bikes below?
  20. IanW1977
    IanW1977
    Dec 30, 2002
    4,585
    West Midlands
    +484
    You'll have to have a sit on them see which geometry suits your physique.
  21. Tall_Paul
    Tall_Paul
    Dec 3, 2005
    8,567
    Kent
    +2,172
    Yeah, it's not only the hieght but also the reach, I'm same height as you and have freakishly long arms, I went to a dealer who let me have a ride on a couple of bikes to get the right height/reach requirements. I ride a felt Dispatch in 61cm size.
    It's a fixed gear/single speed (flip-flop rear hub) so probably not up your street, but I love it :D gets me as fit as hell as you either power up every hill or you walk :laugh: and it's stupidly light for a £500 bike, about 19lbs. No gears to worry about or maintain, easy.
    If it's the Cycle2work scheme then it's just halfords you can buy from, if it's cyclescheme then you can to any independent bike show that supports it.
