HUSTLE Season Three?
Discussion in 'TV Show Forum' started by PeterKay, May 12, 2005.
  1. PeterKay
    PeterKay
    Dose anybody know if there will be a 3rd season of Hustle ?
    Will season 2 be out on DVD and if so when?
    :smashin:
  2. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,411
    71
    Southsea
    +70
    Yes there will be a third season of hustle. Season 1 dvd has only recently come out so prob a while for season 2 to be available. Also the season 1 dvd was cut short so I wouldn''t advise buying it. No doubt they will bring out a season 1&2 boxset.
  3. Barrovian
    Barrovian
    Oct 29, 2002
    924
    Second star to the right and straight on 'till mor
    +54
    What do you mean, 'cut short'? Do you mean episodes are missing or cut?
    John.
  4. PAH
    PAH
    Jan 29, 2002
    1,129
    48
    +63
    There was a thread the other week about each episode on the DVD being only 50 mins long, which might be understandable if it was an ITV show without the adverts, but as it's the Beeb's each episode runs for a bit closer to 1 hour.
    After the last episode of series 2 the announcer said they'd be back next year, which is no suprise as it's still a cracking bit of entertainment.
