hushbox question
Discussion in 'Projectors, Screens & Video Processors' started by sirata, Jul 25, 2003.
  1. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    i`m looking to build a dedicated ht,my question is, would it be worth allocating 2-3 ft at the back of the ht to house all the av
    equipment and the projector,do those of you who have dlp/lcd projectors find the
    fan noise/heat generated bothersome.
    I don`t have a projector yet but i want to cover all my bases.
    has any one made a hushbox,or sited the projector in a seperate room,do you have to use special glass and should the lens be against the glass.
    Lastly i have never seen a projector in action,lack of demos available on the island.
    what would you recommend up to 3k,would be used for
    dvds,sky football,pc games and surfing the net.
    thanks
    Dave
    Guernsey
  2. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    I just built one for my Sanyo PLV30 , yes the fans noise bothered me big time, really found it ruined some movies, but then again the Sanyo runs at 38db.
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Like Ricky, i have the sanyo projector. It bugged me big time so i have built a 'quiet' box. It doesnt silent the thing, but it does cut out a worthwhile amount of noise. Heat can be a problem mind you so i need a fan to keep the box cool. If you have an option to have the projector in another room, i would do it.
    Ad
  4. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    Thanks guys,i think i will build seperate room,as i`m not a fan of
    too many action films,so many of the films will have quite passages.
