Humming noise due to vibrations from sky box
Discussion in 'General Chat' started by p1tse, Aug 24, 2013.
  1. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    Heres my current setup
    The spinning hard drive from the sky box is causing vibrations and out putting a humming noise, bit like a fridge motor.
    Apart from getting rid, moving it else where, is there away to reduce the vibration/ humming noise, as it's rather annoying
    [​IMG]
  2. GaseousClay
    GaseousClay
    Jan 11, 2011
    5,964
    UK
    +7,697
    I had a crappy freeview pvr that hummed so much that it could be heard in most rooms in the house. It was sat on a wooden chest of draws in the bedroom which acted as a sound box. I bought some felt pads for putting under furniture legs and sat the pvr on that. Made a considerable difference.
  3. phillyd1981
    phillyd1981
    Dec 10, 2006
    2,573
    +1,474
    I was just about to suggest felt
    Pads also.
    Sent from my XT910 using Tapatalk 2
  4. Steve N
    Steve N
    Feb 3, 2005
    10,918
    Peterborough
    +2,377
    A really effective cheap fix is to cut a couple of squash ball in half and put one half under each corner of your box.
    I was told this years ago. It works better than pads.
  5. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    Will see what I have
  6. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    Just added some rubber felt sticky pads, but not much difference
    Just hope the new sky box to replace it will be better
  7. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    new one should be better, sure its the hdd and not the transformer?
  8. p1tse
    p1tse
    Jul 24, 2008
    2,974
    68
    +83
    Not sure to be honest
    Actually the added felt pads has helped a little I think
    Fingers crossed new box will be better
  9. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,535
    Poole
    +9,765
    Most likely the fan.
  10. bobflunkit
    bobflunkit
    Jan 29, 2008
    1,402
    2
    2
    116
    +691
    Sounds like hard drive. Got a new box about a year ago and within 6 months I'd had 2 replacement boxes due to very noisy hard drives. Never had a problem up until then and since. Now it's mounted on halved squash balls with extra air circulation all around to keep things a tad cooler.
  11. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,535
    Poole
    +9,765
    Good tip about the squash balls.
  12. Sick Boy
    Sick Boy
    Aug 27, 2003
    2,091
    Bristol
    +138
    Up or down.
  13. bobflunkit
    bobflunkit
    Jan 29, 2008
    1,402
    2
    2
    116
    +691
    Up, like little domes.
  14. True Romance
    True Romance
    Feb 7, 2005
    6,956
    Wolverhampton
    +3,026
    Try turning off the instant rewind feature if enabled. Always turn mine off as the noise does my head in.
