Humming in speakers
Discussion in 'AV Receivers & Amplifiers' started by jay672, May 3, 2005.
  1. jay672
    jay672
    Couldnt find a thread that fit so this seemed like the closest one. I just started hearin a hum in my speakers(annoying as heck) ive changed speaker wire and checked all connections not sure what else it could be. Though maybe the reciever itself. Its a Hk 510 and ive had it forever any help woud be greatly appreciated
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Is the humming throughout the frequency range? If it is then my initial thoughts would be a problem with the power supply or possibly a grounding problem.
