Humming from Mission FS2AV & Marantz SR4200....
Discussion in 'AV Receivers & Amplifiers' started by Stevie G, Aug 16, 2002.
Tags:
  1. Stevie G
    Stevie G
    May 2, 2002
    641
    +34
    I bought these a few months back, and I've noticed there's quite a hum when the Marantz is switched on but there's no sound (or when it's low). I generally leave the Mission sub switched on, and that's fine. What could it be? Could it be a mains problems? Does the Marantz know (or need to know?) that the sub is active?
    Any advice would really be appreciated. It's not really bad, just a little irritating when I notice it.....!
    Thanks.
    :confused:
  2. Shirker
    Shirker
    Oct 30, 2001
    54
    9
    Leeds
    Try checking that all the speakers are connected to the sub correctly.
  3. Guest
    Try the search facility I seem to recall a thread about the Marantz SR4200 humming a few months ago.
  4. mickey moo
    mickey moo
    does it hum when the aerial lead is unplugged ?
