Humming Castle Compact Cube
Discussion in 'Home Cinema Speakers' started by dazed&confused, Mar 12, 2005.
  1. dazed&confused
    dazed&confused
    Mar 12, 2005
    586
    Kettering, Northants
    +35
    Hi. Advice needed please.
    I have bought a Yamaha DSP-AX750SE amplifier (new) and a set of Castle Compact 5.1 home cinema speakers (a few months old from a hifi retailer on ebay).
    My problem is that when I switch the amplifier onto 'standby' mode the Castle Compact Cube (the subwoofer), after a short delay, gives out a quite loud, really annoying hum. It also hums to a lesser extent when the music fed into the amplifier is stopped. If I turn on the subwoofer without it being connected to the amplifier, then is doesn't hum at all.
    Is there likely to be a fault with either the amplifier or subwoofer that might need repair. Otherwise, does anyone have a solution for a cure?
    Thank you.
  2. dazed&confused
    dazed&confused
    Mar 12, 2005
    586
    +35
    No ideas then?
    I guess I've got serious problems.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    That link didn't work for me.
    The problem will be an earth/ground loop. Do a search on the forum and you will get a lot of info to solve the problem.
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,708
    J6 M5
    +214
    It could be an earthing issue. And are the power cables kept away from the speaker & subwoofer cables?
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Me neither so it must have been a limted life thing geared to my user name. All it was a search of the subwoofer forum on the term subwoofer humming and it produced quite a number of threads for "dazed&confused" to peruse
