hummig sound from subwoofer
Discussion in 'Subwoofers' started by rexleroy, Mar 24, 2006.
  1. rexleroy
    rexleroy
    Dec 31, 2005
    33
    hi can someone tell me how to get rid of humming noise from my subwoofer you can only hear it when playing dvd.s the radio-tv video and hard drive are ok model panasonic home cinema sc*ht880
    yours rexleroy
  2. JB38
    JB38
    Dec 6, 2005
    181
    South Lincs
    +10
    Does this happen with all DVD's? as if it does, it would suggest possible instability in the actual DVD playing circuitry and something you cannot really do anything about.
    Also has this just happened?, as a subwoofer is one of the worst things to show up design deficiences like disc drive motor electrical noise. (or possibly through a defective filter component)
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Or an earthing problem? Or power cables lying on speaker cables?
  4. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    Moving...
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Pull the input connection out of the back. If the hum is there without any input, it's either a fault or a design fault. Unfortunately subwoofers are tuned to the very frequencies that a bad power supply will leak out (50 and 100 Hz). I used to have a Pioneer sub that hummed like that - I cured it by replacement.
