Humidity problem in garage
Discussion in 'Home Cinema Building DIY' started by dc007, Jun 2, 2003.
  1. dc007
    dc007
    Nov 22, 2000
    1,091
    48
    London, U.K.
    +47
    With some quality electronics in there, I'm concerned about the levels of humidity in my garage conversion...
    I'm considering one of those dehumidifier machines - anyone got any advice on this, please ?
  2. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Not specifically, but my room is in the cellar of our house and has a higher humidity therefore.
    I keep a dehumidifier running down there to limit this, ideally I'd get one that can be kept on free drainage and can be plumbed into a water waste - I get fed up with having to empty the tank on mine.
  3. dc007
    dc007
    Nov 22, 2000
    1,091
    48
    London, U.K.
    +47
    How often do you find you have to empty the tank, please ?
  4. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Depends on the weather, how high you set it etc..
    TBH it's probably only once a week but I wish it were possible to have it on continuous drainage instead (lazy bugger that I am!).
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Don't forget dehumidifiers will just remove the moisture in the room and the plaster. This allows more moisture to come through, this is not therefore a solution to the moisture problem but more 'controlling' it. It would be far better to deal with the moisture problems especially as it is a garage and to stop it coming through in the first place. Dehumifiers aren't cheap to run either.
  6. dc007
    dc007
    Nov 22, 2000
    1,091
    48
    London, U.K.
    +47
    The model that I'm looking at claims to run at 2p an hour, which is acceptable...
    Beekeeper, what do you mean when you say that it will remove the moisture from the room and the plaster !?
    Are you suggesting it might damage he plaster ??
  7. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Too true although I'm not sure they're particularly expensive to run. Ultimately I'd like our cellar to be fully tanked out to prevent this but needless to say this is going to cost a mint! However, prevention is certainly better than cure.
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    No I am just suggesting that preventing water ingress rather than controlling it may be the best solution for you, particularly in a Garage. A cellar is a bit different, Just ask spectre!
