humax stb and dvd recorders
Discussion in 'Blu-ray & DVD Players & Recorders' started by frankie13, Oct 9, 2003.
  1. frankie13
    frankie13
    May 14, 2001
    700
    england
    +8
    hi m8s im thinking of buying a dvd recorder, now i want this lot to work ok on it .
    a humax stb
    a ptae 100 projector
    and a dvd player what do you recommend m8s
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Why not go for a DMR-E50 and an RGB to YUV converter or an HS2 depends on the Spec of the HUMAX what model is it????
  3. frankie13
    frankie13
    May 14, 2001
    700
    england
    +8
    its the 5400z i use rgb scart to s-vhs video the s-vhs cable into a pro-v box then vga cable into projector for sound i use optical output on back of humaz into a amp
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    how do you go from RGB scart to S-Video ????
  5. frankie13
    frankie13
    May 14, 2001
    700
    england
    +8
    rgb scart from humax into vcr then s-vhs lead from vcr into pro-v box then svga cable from pro-v into projector
    so whats your recomendation on dvd recorder to buy
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    If going into VCR unless its very advanced you are only getting composite. so you need to start again.
    Why not Humax>DMRE50>RGB>VGA box>Screen and drop the ProV
  7. frankie13
    frankie13
    May 14, 2001
    700
    england
    +8
    all these go into s-vhs vcr. humax + dvd player all rgb then the
    super vhs lead goes into the pro-v the pro-v improves the picture quality then the pro-v takes over the svga cable goes into the ptae 100 i think is excellent
