P
pbutterworth
now explain to me, why on earth would you ever want to record two recordings are off the same mux? Doesnt that mean 2 of the same channel?
I would certainly expect so, the Digifusion FVRT200 already does this for example.Timh said:Will it be possible to record 2 channels and play back a recording at the same time?
Timh said:Theres a source button on the front! does that mean we can record from an external box like Sky?
scotte said:Bit of a newbie question but I assumed that most PVRs would take an external signal (ie my telewest box) via an rgb scart. Is this a completely incorrect assumption?
bowler said:PVRs will not do this.
scotte said:Bit of a newbie question ?
It's more probably because they are marketed as Freeview PVRs.scotte said:I suppose that's why so many of them have built in freeview.
DVD rec with HDD. Correct. aside from the hard to obtain and more or less obsolete (in the UK) TiVO, a HDD-DVD is the way to do it. Ideally, get one with Set Top Box control (and maybe GuidePlus TM) to make the job of setting timers much, much easier. eg the Pioneer 530.scotte said:Is there anything similar that I can connect my telewest box to (eg dvd rec with HDD)? I was kinda hoping that this new humax would.
LV426 said:aside from the hard to obtain and more or less obsolete (in the UK) TiVO, a HDD-DVD is the way to do it. Ideally, get one with Set Top Box control (and maybe GuidePlus TM) to make the job of setting timers much, much easier. eg the Pioneer 530.
LV426 said:So, Cyril, which High St store do I go to, to buy a new one?
