Humax Pvr8000t
Discussion in 'Digital TV & Video Players & Recorders' started by vikingbones, Aug 7, 2004.
Tags:
  1. vikingbones
    vikingbones
    I am thinking of buying the HUMAX PVR8000T and I was wondering if it has a fan and if so is it noisy. I have heard that some hard disc recorders are so noisy it makes it impossible to use them.
    Also does anyone know where I can read a review of it.
  2. Sym_T
    Sym_T
  3. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    Much quieter than my Sky+ box, pretty sure there isn't a fan, excellent recording quality, easy to use and I think it looks good - especially when you remove the protective plastic from the box and remote!
    Also for £122 delivered it's a bit of a bargain - it doesn't have two tuners but, for the price, you could always buy a second one!!
  4. Ged
    Ged
    Apr 29, 2002
    946
    +24
    I bought one this weekend, when sat outside the tv unit I thought it was noisy but when installed it's fine.
    The chasing playback feature is good as is the reliability over my Twin, lots of 0s recordings on Saturday!
    Definetly worth it, recommended
  5. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    There is no fan in the PVR8000T, but in this weather it could probably do with one. The temp inside the box can be pretty high after it has been on a while with both the PSU and the HDD churning out heat. Normally it's ok but in the high temperatures that we have had recently, it's sailing a bit too close to the wind. Possibly why a few people have reported strange reboots. I'm thinking about fitting a speed controllable fan (slow and inaudible) powered from the HDD 12v supply just to help the existing convective cooling system (holes in the lid!).
  6. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Juat took delivery of mine and it's very, very quiet. Much quieter than Sky+. Can barely hear it from 6 inches and not at all from the sofa, which is 3 feet from the AV rack.
    I think hard drives vary though so it may be down to luck.
  7. Flak_Munky
    Flak_Munky
    I don't find it that noisy, although I don't think mine is as quiet as Ste's... I can hear a very quiet hum when it is switched on, but it is not as loud as my PC!!! :( With your TV at normal listening level you won't be able to hear it, if thats what you're worried 'bout.
    Overall, its a good machine, now the 7/8 day EPG is out! ;) As long as you are happy with the single tuner (can't watch one FV channel and record another FV ch) then you won't be disappointed!
    Some users have reported that the Maxtor DiamondMax 9 120Gb drives are even quieter than the standard one... and they can hold 60 hours....
    Regards,
    fM
    I love it! All I need now is a DVD recorder... :)
    fM
  8. wadeall
    wadeall
    Seems very quiet to me. Ive been using it for a couple of weeks now and very pleased so far.
    Wade
